I have an amd 1.2ghz and MSI K7T Turbo, and my computer is rerally unstable. Whenever i play games, it either freezes or a beeping noises comes up and i cant move my mouse.
Please help me if you have any idea.
More info is necessary to truely address whatever is causing your problem. This info includes:
1) operating system
2) rating (in watts) of power supply and how many drives and fans are running off of that power supply
3) what sort of temps are you running
4) how many programs are you running in the background while playing games
My first guess is that it is heat related (but that isn't an educated guess at this point). I am not too familar with MSI motherboards but, the beeping could be a temperature alarm. If you have no idea what your temps are then you probably need to go into your bios and check that out. As a backup I would recommend downloading something like motherboard monitor 5 to track your temps while you are gaming. Play your game(s) for a while then exit before it locks up and check the temp history.
I hope this helps ... If you need any further help or clarification feel free to post ... but I would recommend posting in 'AMD CPU's.'
As the previous post said, post more info about your system. Also, if you haven't got temp monitoring software yet, you can get it here, which goes to tweakfiles.com.
