Help!
[OC]Lucifer
Brainerd, Minnesota USA
Ok so here's the deal... I just recieved the Pentium II Xeon CPU I bought off of Ebay for 20bucks :) The problem is I need a Xeon / Slot2 mobo. I need one for cheap. Preferably less than 200, if you can find one for cheaper cool. I would prefer to find a single Xeon mobo, if such an animal exists. Also, if you guys have one or know someone who would part with their xeon mobo for on the cheap. Please let me know. I want to use this fast CPU bad and I need a mobo for it. Please dont tell me I can only use it for a paperweight. Thanks.
I think that you are stuck for finding a slot 2 for under $200, they are usually around $400, but then again if you got a xeon for 20 bucks you could pull off a cheap mobo too.
