- Apr 29, 2003
- Brooklyn, NY
I just installed the A7V8X Deluxe Mobo PCB 2.0 and it didnt go so well.
Startup went okay at first. the system booted without any errors.
I was cocky, and decided to fiddle around with the BIOS. I have an unlocked CPU, and set the mult to a simple 12.5 and the FSB to 166. I have an Athlon XP 2400, so those settings should be doable without any problems.
the system failed to boot, so I cleared the CMOS as per the Manual's instructions and tried again. I got a Memory Error from the POST reporter and the system shut down.
Now it wont even POST.
Ive tried to clear the CMOS again, but it didnt do anything.
Ive let it sit, the CPU isnt even more than 20C, so its not heat. I tried removing the RAM and placing it into another Machine. And the DIMMs are still good.
Help
Help
