Help
Hardass
Senior Member
WU 92% complete and rig reboots. Now will not let me back in VM.
Adak
Senior Member
Did you sign in just before trying this, as su (super user)?
su <enter>
enter user name <enter>
enter password <enter>
Be careful with the password because the cursor will not echo your keystrokes to the screen.
Hardass
Hardass
Senior Member
su <enter>
Got in, chmod +x fah6 did the trick. But lost another big unit that was 92% done.:temper:
Adak
Senior Member
That's a shame on the loss of the WU.
Linux is weird that way though. You can run a file one time, as a super user, but 5 minutes later, you can't, because it's booted you down from that status.
Glad you got it sorted out, now.
Hardass
Hardass
Senior Member
And now will not reload a new one.
Code:
[email protected]:~$ cd ./folding
[email protected]:~/folding$ ./fah6 -smp 8 -bigadv -verbosity 9
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
8 cores detected
--- Opening Log file [January 9 01:55:35 UTC]
# Linux SMP Console Edition ###################################################
                       [email protected] Client Version 6.24R3
                          http://folding.stanford.edu
Launch directory: /home/vm/folding
Executable: ./fah6
Arguments: -smp 8 -bigadv -verbosity 9 -smp 8 -bigadv -verbosity 9
Adak
Senior Member
Code:
8 cores detected
Executable: ./fah6
Arguments: -smp 8 -bigadv -verbosity 9 [B][COLOR="Red"]-smp 8 -bigadv -verbosity 9 [/COLOR][/B]
You need to set up the client so it has just one half of the flags. I've marked the duplicates in red - they have to go.
Are you trying to confuzzle the FAH servers? :D
Jolly-Swagman
listed twice
Have you got -smp 8 -bigadv -verbosity 9 also in the Alternative Arguments too when you set up config
Edit -- Adak beat me too it..
Hardass
Hardass
Senior Member
Shut it down, too tired to fool with it. Was going to switch out hardware anyway.
Hardass
Hardass
Senior Member
Back up soon. Installing Vista 64 on it now figured I would try this one. 9800gx2 arrived today as well.
dylskee
Central MA
62,000 Point WU?!?! either that's a big 'ole typeo or I've missed a lot while I was gone.
Not a typeo, the -bigadv and the bonus for finishing early will get you BIG points. Just finished another 62,000 pointer should be showing on my stats by 9:00 pm tonight.
Adak
Senior Member
Gary:
You've missed a lot, Gary!
The extra big WU's are an extra big deal - get on them if you have something with 8 cores that can fold very intensive WU's, for short deadlines.
Hardass:
How are you doing with removing the extra flags?
Hardass
Hardass
Senior Member
Gary:
Hardass:
Installed Vista, VM up an running, but can not see it on Vista either. But it is running.
Adak
Senior Member
Unfortunately, I can't help you with the kind of set up you have. I only use NotFred's, so I never see the Linux terminal as you do. What I need is right there in the VM Window, and you set your monitoring software to the name the VM shows you. It's like "fold-4ACB", and I have to tell the monitoring software that this is a VM.
I don't even KNOW how to set up your configuration. I believe Charles has some of his rigs set up that way, though. What install directions did you follow? I should really read up on it.
Adak
Senior Member
Well oddly, I've used that guide quite some time ago, (before Sydney joined our team, actually), and it was a bit different), to set up folding in native Ubuntu. I didn't share anything though, and there was no VM. Just Ubuntu, and folding. FahMon monitors them, (there was no HFM then), but you have to be plugged into that rig to see what's going on - no network.
Sure, Ive changed them over for the bigadv WU's, but that was small potatoes to do.
Looks like you've got the VM software underneath Ubuntu, yes?
Do you have FahMon or HFM working yet?
Samba status is ?
I wasn't paying a lot of attention to the Samba stuff, because I don't use it, and have no knowledge of it. If you'll spell out exactly where you are, it will help ChasR or somebody else, know just where you're stuck.
And I will read along and see what I can glean from it, as well. What monitoring software are you trying to use? Is that what you "can't see", or do you mean the shared folders on the other rigs?
Hardass
Hardass
Senior Member
Samba status is ?
VM Software under Ubuntu? No idea what this means!
Do you have FahMon or HFM working yet? No does not show on network.
Samba status unknown.
