I just installed, and every time I try to start it up it gives me an error and exits
The sequence of events is like this.
1) I start the application up, and the little red gear show up in the tray.
2) I click on the gear and the display opens up.
3) Letters strart printing across the top __really slowly___
4) The the error pops up and it closes down.
I tried using the screensaver only version, but the same thing happens.
I'm running win2k on a pIII, 512megs of ram with a Matrox G450 Dualhead graphics card. I only bring up the graphics card because I'm running two mis-matched monitors off of it (viewsonic PF790 and optiquest Q71), and that has given other apps issues in the past. (can't run jspager, because it looses track of windows on screen 2).
In any case, I'm not running [email protected] full screen or on screen 2, so it really shouldnt be a problem.
winfah.exe has generated errors and will be closed by Windows.
