- Oct 2, 2002
- Hawaii / USA
This is what I had before and the system is 100% stable.
I was using a tbird 1.4 10X140, vcore 1.575, ram timing at turbo, CAS 2, and the rest in the bios setting are default, everything was fine until I change to a unlock XP1600 (unlock).
I am getting BSOD, lock up with high pitch noise coming from the speaker, boot back to the desktop most of the time during 3D application, 3Dmark, MOHAA, and a couple time in internet explorer and email, I am getting radom problem sometimes 5 min after games and sometimes after couple hours of gaming, running 3Dmark in loop overnight ~8 hrs always get the blue screen, only 1 time it went thru 10hrs without error.
Things that I did during replacing the processor, ASII the northbridge HS, replace my ATI 8500 HSF with blueORB(fan power from MB header), add ram sink (radioshack) on the vcard BGA memory, cut an extra 80mm hole on my Lian-Li casing, below the stock exhaust fan, clean install XP pro SP1.
I already try using MrIcee bios setting, up vcore to 1.8 and 1.85, processor at all different speed(12.5X133 12.5X140 10X140 10X150) replace the 2 stick crucial 2100 with new one, run my rig straight to the 110 outlet without the UPS, and my system temp is 34C and cpu idle 36C( using WPCREDIT colling) under load 45C using TOAST, I can run sysoft sandra burn in test overnight over 100 time without error, voltage in via monitor looks good except 12v was reading 12.01 during idle and 12.24 under load, seems like problem is with 3D application.
Thanks for reading the long post, I have running out of idea on how to make my rig stable, please help. Mahalo.
