This post is a follow up to my last http://www.ocforums.com/showthread.php?t=428952
I have settled on the following
Case: Cooler Master Centurion 531 KC-531-SSN1 $50
CPU: AMD Athlon 64 3700+ San Diego 1GhzFSB Socket 939 $234
Motherboard: Chaintech VNF4 Socket 939 Nvidia nforce4 ATX $69
Memory:Corsair Value Select 1GB(2x512kb)240 Pin ddr2 sdram (pc2 4200) $64
PSU: Fortron Source FSP400-60THN-R Blue Storm $57
HD: Segate Barracuda 7200.7 160GB 7200rpm IDE Ultra ATA 100 $82.50
GPU: Sapphire 586L Radeon x300se 128MB 64-bit PCI Express x16 Low Profile $49
Sound:Chain Tech AV-710 8 (7.1) Channels 24-bit 192 KHZ PCI interface $25
What is a decent DVD burner to round out the system?
Well that's it, if anyone has any better recomendations or see something that won't work please let me know.
Otherwise:
1. I plan on running XP 64 but don't use any 64bit programs will this be a problem?
2. I want to install the hard drive from my old computer????
3. Once all this is put together is there a C:/ screen ready to load the o/s or is there some formating before that step
4. The above Cosair Memory came with different pins I have 240 is that correct??
Thanks again for everyones help I hope this turns out to be a fun rewarding experience instead of a regretable nightmare!!
Otherwise:
