fastwrites lets the processor communicate directly to the videocard bypassing the system memory (you'll see a slightly larger gain when using SD ram then you will when using DDR or RD ram)
to use fastwrites your motherboard needs to support it and it must be activated in the BIOS. you can use Sisoftware Sandra to see if your motherboard supports fastwrites.
i use the Geforce Tweak Utility from
www.guru3d.com to tweak my card, the problem is it only works with the 29.80 detonators or lower. i'm pretty sure the riva tuner will let you activate them, you can get it from the same website.
i don't know that much about sideband addressing but i know it's similar to fastwrites, your not supposed to use both at the same time because they both have the same goal.
