- Feb 2, 2001
- Chicago, IL
...I saw this idea mentioned in another thread, and already had the parts on order. Right now I have an Alpha Pal 6035 with a Sunon 60mm fan on it. On the left side of the case there's a 120mm Sunon fan blowing air in. I just got a 430w Enermax hoping it would suck more air out and hopefully even out the airflow, but unfortunately it hasn't. I just cannot get even airflow with this case due to it's crappy design. I have an 80mm fan in the front bottom and a 60mm one on the back(due to the bevel in the case). Here's the idea we were toying with:
I'll take an 80mm->60mm fan adapter for the Pal and put an 80mm fan set to suck. I've got the 120mm fan right above it (on the side) set to suck also. I'll put another hole on the side to suck air in (the bottom front fan can't do a whole lot due to the front shell). Now, the 60mm fan on the back will be set to suck air in for the purpose of evening out the airflow.
Does this sound like a good idea? Am I missing anything?
Thanks.
Thanks.
