I took the 80mm fan off. Took 2 92mm 40cfm fans and stacked them in a stair formation so that the fins line up at the center of the hsf. This way you don't have a motor not pushing any air where the cpu is. Unfortunetly I only have a tbird 650 which is running at 866 to test, I broke my 1ghz axia
. 133x6.5 1.88vcore. Mobo temp is 28c. Idle cpu temp is 32c. 25min Full load is 36c but I think it could possibly go 37c if left longer but it isn't showing any sign of going higher.
I've got more plans to make a directional shaft that would surround the MC462 sucking the air out of the case. It would have to be a high powered one to suck away the 80cfm the 92mm fans blow though. What do you think so far?
