I think he is talking about the A7A266(ALi MAGiK 1), If that is the case, the motherboard is competitive to Iwill KA266(ALi MAGiK 1), but not quite as good as A7M266(AMD760). If you want to use SDRAM now and DDR later, the A7A266 is for this purpose. For performance wise, A7M266 has the edge and 3 Dimm slots are better than two. MSI motherboard will use the VIA KT266 chipset and probably no one else will be using AMD760 chipset except Asus.
