hey, it DOES work!
james.miller
Dunstable, uk
what am i talking about?
using an empty fan housing as a conduate of sorts to direct the flow of air on a heatsink fan (by stacking the fan on top if it, and securing the empty housing to the heatsink)
my idle temps droped 2-3c on my athlon by doing it.
iv'e now got a very-quite 80mm fan (about 14-16dba i think) on my volcano 7 and it idles at 41c.
also, this method seems to dull down the noise of the fan aswell.
man i couldnt believe it actually works! its sooo quiet now, that my psu fan is starting to annoy me!
its a bit warmer than with my 92mm fan, but damn! its even quieter!
Cheesy Peas
Rotherham,UK
is that the stock fan on it?
ive got a v7 and if thats with the stock fan then i might do the same.
whats the depth of the fan hosung youve got on it?
mbentley
Gloriously Lead, Overclockix Chief Architect
Indianapolis, IN
sounds like it's time to go find a dead fan and build myself a little fan tower, if you will. :D i'll let you know what the results are for myself.
james.miller
james.miller
Dunstable, uk
standard 80mm housing and no, it isnt the stock fan. i killed that! lol
its a very slow fan that spins at 2000rpm max i would imagine, low airflow, very quiet. It doesnt even have half the airflow of the standard v7 fan - which should tell you guys how quiet it really is.
edit: its about level noise-wise with my 80bg maxtor ata133 hdd
james.miller
james.miller
Dunstable, uk
yeah it was mentioned here a while ago, but i forgot all about it until i found a dead 80mm fan and though "hhmmmm... lets experiment!"
Cheesy Peas
Rotherham,UK
nice so i should get some pretty good results with my v7.. im lapping it at the mo too
how did you kill your fan.. i killed one on my ex Volcano j by sticking my finger in it and breaging one of the blades... whih was rather painfull and messy!
Stedeman
The Half Asleep Member
Lewiston Maine
I killed a few when cleaning them with compressed air and accidentally letting them spin................................zip now they make a funny noise (to bad I tossed them)
PS I still clean them the same way
james.miller
james.miller
Dunstable, uk
im not exactly sure! lol
one day i turned on my pc and boom! bright flash and smoke from the fan. im lucky the pc works at all!
