I dont see a list but...can you have a look at this list please the 6850 should be faster than the 7770 i am looking at amd again because of the price so i can get a bit beter gpu
http://www.anandtech.com/bench/Product/539?vs=536
OK, so let us be clear:
AMD CPU -> you won't be able to do what you're aiming to do (games + multithreaded heavy applications) for this kind of budget.
Don't consider old CPUs, they are about the same than the actual ones in lower range (high end from last year -> middle range this year, middle range last year -> low range this year).
So basically, you have the choice:
Do what you want to do while going Intel
OR
Go AMD but accept some sacrifices.
AMD is great for many applications, but can't be taken in your particular case: you are asking too much for a small budget
For the GPU:
Yes, the 6850 goes faster than the 7770 but consumes 50 more watts: you will really quickly repay your 20 or so euros with your electricity bill
The problem is the same than for CPUs: older consumes more, costs about the same and don't have necessarly far greater performance than the new ones in a lower end.
The 7770 is fine for your low resolution, don't worry about it.
For the PSU:
Go better quality and lower wattage: as easy as that. The best quality are Seasonic but it may be out of your budget. Corsair build really good PSU at low power (the CX series are Corsair).
If you really need help, please be clear about what you want and what is exactly your budget!
If it remains the same than what you explained at the beginning of the thread, the answer has already been given by ED.
Piledriver is better...
Well, 3570K vs 8 core, in heavily threaded applications PD should win. Single/quad threads, the 3570K should win.(been over this before in one of your other threads... this is why we say stick to one!!)
My apologies, I didnt reply in your duplicate thread (still should only start one!!!).
Anyway, It depends on the applications you use. If they make heavy use of more than 4 threads, then the PD is the way to go. If its quad or less, I would go 2500K/3570K.
Above I linked a site that compares videocards... check that, but a 7850 is faster, uses less power, etc.
I'm not a moderator so I cannot delete threads. You can however report your own thread by pressing the exclamation point and saying to delete the thread.![]()
There are brackets for doing so, yes. But note laptop HDD's are usually slow (saves power/heat). Check out the model, RPM, cache size, etc first. It should be 7200RPM. I personally wouldnt get anything less than that for such a nice system you are building. The HDD is by far the slowest part in your system.
Disregard if that is only for data and not yor OS.
As mentioned earlier, the 8c CPU (FX) would be better than the quad core for applications that use more cores than four.
That said, are you sure that motherboard supports the FX line? Im not an AMD guy so I dont know. I suggest you go to the Asrock website and navigate to that board and check its CPU compatibility chart to confirm/deny.
EDIT: Looks like it does with the original bios so you are good there.
hi i am on a bit of a budget so i am looking to spend about 520 euros max on my rig and i found some good deals but i do not know if they will work together can you please help me out my current pcs are a laptop with 8gb ram i5 [email protected] 2410m and a nvidea gfore 315m with cuda and an old pc with 1gb ram and no graphics card and a 300w psu and a hdd of 384gb
these are the parts i want for my new pc i have never built one myself
amd fx 8120 8core 16mb cache
CiT Jupiter Midi Tower Mesh Gaming Case
8gb corsair vengeance
radeon HD7770 1gb
Asus M5A78L-M/USB3 Motherboard
CIT 500w Gold 12CM Silent Atx Power Supply
Arctic Cooling Freezer Xtreme Rev.2 CPU Cooler
seagate 3.5 inch baracuda 7200RPM
here are the links
http://www.amazon.co.uk/AMD-FX-Seri...UTF8&colid=P4J2K9GHTWJ9&coliid=I3ILZOIOAAKDF3
http://www.amazon.co.uk/CiT-Jupiter...7PU6/ref=sr_1_6?ie=UTF8&qid=1355327243&sr=8-6 http://www.amazon.co.uk/gp/aw/d/B004QBUL1C/ref=redir_mdp_mobile?qid=1355321589&ref_=sr_1_2&sr=8-2
http://www.newegg.com/Product/Produ...yMark=False&IsFeedbackTab=true#scrollFullInfo
http://www.amazon.co.uk/Asus-M5A78L...et/dp/B0054U7HIO/ref=pd_bxgy_computers_text_z
http://www.amazon.co.uk/500w-Gold-S...YFO6/ref=sr_1_7?ie=UTF8&qid=1355327939&sr=8-7
http://www.amazon.co.uk/Arctic-Cool...UTF8&colid=P4J2K9GHTWJ9&coliid=I1ZFLIDIBAWZG5
http://www.amazon.co.uk/Corsair-CMZ...1_2?s=computers&ie=UTF8&qid=1355328022&sr=1-2
http://www.amazon.co.uk/Seagate-ST3...1_4?s=computers&ie=UTF8&qid=1355328061&sr=1-4
