Hibernate resume error
Pla
San Francisco, CA
When I try to resume from hibernate it reads the whole bar and then it waits with monitor off for 2-3 secs and then it shows blue screen:
KMODE ... exception not handled ....
Same happens when restoring from stand-by.
It was working fine with my old board. I upgraded the mainboard and VGA. Installed all newest drivers. Everything else works fine.
Don't have idea what to do.
The OS is Win2000 SP2.
Heat
Florida
I have heard quite a few people say that they have had issues with hiberations but never w/ standby. I guess you can mess around with your power management settings and search for that error at M$'s site.
P
Pla
San Francisco, CA
I found something ralted to this - in SP2 they have included a fix for viaagp.sys. My old notrbridge was AMD760 and the new one is via... (kt400). Whie updating the dirvers I tried once to use recover... so I'll try to reinstall SP2 to see if this fixes it.
turd
You could try running from your cmd
SFC /SCANONCE
which will run the system file checker and replace some system files as necessary. Have your 2K CD ready. Not sure this will help but worth a try seeing you are already at the reinstal stage.
P
Pla
San Francisco, CA
Thanks for the tips!
I just found out what was causing it. I tried hibernate with no extra proccesses and it worked. Then by elimination ...
It was the EXPERTool - tool for tweaking the Gainward GF4 and some extra functions. It was starting from the registry - LOCAL_MACHINE\S...\M...\W...\Cur...\Run so I removed it. At least I know what to look for now. And I don't need it running anyway.
JimmyG
Michigan
I'm running W2K on an A7V333 mobo. I have exactly the same problem. I have been experimenting by removing working processes in task manager, then hibernating and restarting. So far, I have been unable to fix the problem. I seem to remember that in Win98 there was a tool where you could check or uncheck startup items that were both in the registry and the startup folder. So far, I haven't been able to find the same tool in W2K. Do any of you know if that tool exists???
