- Apr 22, 2004
- Sonoma, CA
I am determined to create a completely hidden computer that is quiet.
Right now I'll probably be using an ASUS A7N8X, Athlon XP 2400+ Barton core, Geforce 6200 (passively cooled) or 8600GT (if I can get a passive cooler on it and to work right). I may also do a little shopping for a better CPU cooler, but the one I have is not terrible especially considering I have the cpu OC'd.
I don't game, the computer just needs to be on basically 24/7, be stable and do normal web browsing and homework related stuff as well as work as a passable HTPC. I have a Hauppauge pvr-150 right now, and a lot of movies/shows on the HDD, very little if any HD content, not really a concern of mine.
SO:
I figure the best option is to build the computer into a night stand or set of drawers. What do I need to consider with this option? How should I mount the mobo? Should I just use the mounting screws for the case but screw it into the bottom of the drawer? Will this allow enough dissipation of heat?
How should I vent the system? I only want fans in back, so should I just try to get an in flow on one side and an out flow on the other side in the back? Basically how do I ensure a quiet cooling system considering my not so big need for cooling?
Anything else I need to consider?
SO:
