- Oct 30, 2006
I need help making sure I have it set up right. The problem is I would like to get my E6700 on a P5W DH Dlx to about 3.5 MHz but my room temps can hit sometimes above 30 C. This obviously makes it quite difficult to keep the system cool. My case side and top panel are thin foam which does wonders for not letting dust through but it also restricts airflow somewhat.
Will any kind of an air cooling solution enable me to get to the above OC?
Can it be done better then as per attached?
Should I abandon air solution and go for water?
Any other suggestions are most welcome.
