- Feb 12, 2004
- The Netherlands
In the next few weeks I'll be putting the final order in for a new laptop. My original choice was going to be an Asus G75, but nowhere is there one in a configuration that I want. I also refuse to buy a 'cheaper' one and upgrade it. Seems like a lot of work for a laptop costing Euro 1500 ++
Anyhow, the final battle is between a pair of BTO (Build To Order) laptops here in The Netherlands/Europe. I'll list both specs, the price, my own pro's and cons aswell as what I plan on using them for. Any input from you lot would be appreciated. It's nice to have a broad opinion and see what others think.
(Note: It's the Dutch language, but for the specs I'm sure you smart cookies will understand. I deleted the irrelevant stuff for the most part)
X•BOOK 17CL48-GTX660 i7 QUAD FULL HD - NVIDIA GTX660 + SSD-HDD
Price for this config: €1.975 = $2.436 USD
Beeldscherm: 17.3 inch FULL HD LED - Ontspiegeld (mat) / True NON-Glare, (res. 1920x1080)
Videokaart: NVIDIA® GeForce® GTX660M 2Gb GDDR5, PhysX™ + CUDA™ + Optimus (batterij-besparing via Intel® HD Graphics 4000)
Videokaart: Intel® HD Graphics 4000 (2e energiezuinige videokaart), wordt ingeschakeld als NVIDIA wordt uitgeschakeld.
Chipset: Mobile Intel® HM77 Express Chipset
Processor (IB): Intel® Core™ i7-3610QM Processor (Quad Core, 6MB Cache, 2.3 GHz, Turbo Mode 3.3GHz)
**Processor koeling: Artic Silver koelpasta (Systeem wordt beter gekoeld, tot 6 graden winst)
**RAM DDR3 1333/1600 (1): 8GB Corsair First Class Vengeance DDR3-1600MHz (slot 1)
**RAM DDR3 1333/1600 (2): 8GB Corsair First Class Vengeance DDR3-1600MHz (slot 2)
**RAM DDR3 1333/1600 (3): 8GB Corsair First Class Vengeance DDR3-1600MHz (slot 3)
**Harddisk: 240GB SSD Intel 520 series, SATA-3 (Max 550 MB/s lezen / 520 schrijven)
**Harddisk (2e): 750GB HDD 7200 rpm 16Mb cache
**Optische disk / Extra interne harddisk (Caddy): Blu-Ray (R)W Brander 6x + 8x DVD-(R)W
**Wireless / Bluetooth (Combo): Intel® Centrino® Advanced-N 6235, Dual Band AGN (2.4/5GHz), 300MB + Bluetooth 4.0 (Wireless Display)
Accu: 8-cell Primary Lithium-Ion Battery (76,96WH)
USB 3.0 - 2.0: 3 x USB 3.0 + 1 x USB 2.0
VGA-poort: 1 x D sub 15-Pin VGA poort
HDMI Poort: HDMI 1.4a aansluiting voor extern LCD scherm / HD TV (1080P / met HDCP)
Webcam: Ingebouwde 2 MegaPixel WebCam + Microfoon
E-SATA: Externe SATA aansluiting voor snelle schijven (E-SATA)
Keyboard: Notebook keyboard incl Numeriek keypad
Keyboard Layout: QWERTY Toetsenbord (VS-Internationaal voor NL)
LAN: 10/100/1000 GigaBit Ethernet (RJ45)
Cardreader: 9-in-1 card Reader (MMC/RS-MMC/SD/Mini-SD/SDHC/SDXC/MS/MS-Pro/MS-Duo)
Audio: Microfoon-ingang, Speaker uitgang + Digitale uitgang (SPDIF)
Audio: 7.1 Digitale audio uitgang, THX TruStudio Pro certificaat
Audio: Ingebouwde Stereo speakers
Beveiliging: Intel Trusted Platform Module (TPM)
Afmetingen: 413mm (B) x 277.5 (D) x 17.5~44 (H) mm
Gewicht: 3.2 Kg
Adapter: 120 Watt adapter inclusief netsnoer
**Garantie >: 2 jaar Pick-up en Return warranty BENELUX
Reiniging TFT: BTO TFT Reinigingsdoek, Microvezel.
AKTIE: GRATIS BTO Draagtas + USB muis + muismat + stereo oordopjes twv 39 euro
Links: http://www.bto.eu/html/detail_home.asp?PartnerID=1&lang=nl&DisplayPartnerID=1&ProductID=585
X•BOOK 17CL47-7970 i7 QUAD BACKLIGHT KEYB - ATI/AMD 7970 + SSD
Price for this config: €2.300 = $2.836 USD
Videokaart: ATI HD / AMD Radeon™ HD 7970 2GB GDDR5, Enduro dynamic switchable graphics, OpenGL 4.2 support
Videokaart: Intel® HD Graphics 4000 (2e energiezuinige videokaart), wordt ingeschakeld als AMD/ATI wordt uitgeschakeld.
RAM DDR3 1333/1600 (3): 1 Lege geheugen uitbreidingslocatie (slot 3)
RAM DDR3 1333/1600 (4): 1 Lege geheugen uitbreidingslocatie (slot 4)
**SSD Module (mSATA): 128GB mSATA SSD Module Crucial RealSSD M4
Display Port: 1x Display Port 1.1a
DVI poort: 1x DVI-I aansluiting (Single Link)
Keyboard: Keyboard met programmeerbare achtergrondverlichting incl Numeriek keypad (Backlight Keyboard)
Audio: Microfoon-ingang, Speaker-uitgang + Digitale-uitgang (SPDIF) + Line ingang
Speakers: Hoge kwaliteit Onkyo Speakers inclusief Sub-Woofer
Firewire: 1 x IEEE1394 FireWire poort
Beveiliging: Ingebouwde vinger-afdruk sensor voor wachtwoorden en login-namen
Gewicht: 3,9 Kg
Adapter: 220 Watt adapter inclusief netsnoer
Links: http://www.bto.eu/html/detail_home.asp?PartnerID=1&lang=nl&DisplayPartnerID=1&ProductID=566
Pro's: -It's cheaper, around 325 Euro +-
-660M Kepler card, cooler, more power efficient. Although Optimus HD 4000 is available aswell, so should make battery last longer
-I like the keyboard. No funny LEDS, nice spacing between the keys
-I'm guessing it's triple channel memory. Originally came with 2x sticks, added a 3rd and upgraded the lots to 3x 8GB Corsair. Not sure if this is any better then 2x Dual channel sticks though.
-nVidia driver support, yay
Con's: -660M nowhere near a 7970M in terms of performance
- *only* 24GB memory instead of possible 32GB
-Standard funky audio speakers? I think everything is THX certified nowadays
Probably going to have to buy a good headset regardless.
-No option for an mSata SSD, so minus 128GB which would have been nice. This being said, I guess you could always buy another Intel drive and use it externally via E-Sata. Might be faster then the Crucials aswell.
X•BOOK 17CL47-7970
Pro's: -Onkyo speakers (any good? No idea)
-Top end 7970M video card, which blows the 660M away. Possible better for longetivity
-Option for an mSata SSD. Albeit not as fast as normal 2.5" SSDs
-Memory upgradeable to 32GB
Con's: -I'm not sure about the LED keyboard. Not a big fan of the keys being so close together
-More expensive
-Possible driver issues with ATI? Never been known for good driver support and Eve Online is partnered with nVidia Not sure if that makes a different or not. Would rather not have issues running multiple clients. Although I still have my desktop
Ok, this is what I would use this laptop for:
-Gaming, BUT...I've never run anything at max res full AA/AF really. I don't like it. Hell I still use 1024x768 in some area's. My 24" desktop screen has Windows @ 1360x768 ...hence the debate for the 660M vs 7970M.
The games? SC2, D3, Multiple Eve Online Clients, World of (Russian) Tanks
-Workstation with regards to Server Virtualisation, either via VMWare or Hyper V. So yes, multiple images live all at once
-School projects/homework
This is pretty much a DTR, hence the pricetag. This isn't something I'd plan on replacing in a few years time either. Possibly 4-5years++, obviously depending on how well the hardware lasts. Thanks for reading if you made it this far
Note: The ** in the specs are the parts I modified/upgraded
Gewicht: 3.2 Kg
Gewicht: 3,9 Kg
X•BOOK 17CL47-7970
-More expensive
