You'll get a natural delta between core temps at max load as all of the cores are not identical (manufacturing tolerances) within the chip. However, with a 12 C delta between the highest and lowest, you might not have solid TIM coverage on the CPU. Might be worth reseating the cooler.
If that doesn't have any effect, it could be the interface between the die and lid of the chip. You could be hitting the limits on the thermal conduction capabilities of the chip.
I wouldn't go any higher with the OC until you get this figured out though...it's 60 F now there in the winter. Let's say you hit 80 F ambient in the warmer months...that's a 11 C increase in ambient...which will add almost 1 to 1 to your chip temperatures...putting you in dangerous 100 C temperature for cores 2 and 3.
