High temps?
Radical
CA
What kind of fan(s) are you using? Unless you're using two Tornados or Deltas 45C seems fine.
archilochus
THE Senior FANMAN
Houston,TX-USA
What are your ambient (room) and system (case/mobo) temps..What is your load temp..Idle doesn't tell you much about whats going on..Load it up to 100% cpu usage and report all temps..Maybe we can see whats going on here..:)
