hey guys i have a couple questions...
last year i build a pc with a ryzen 5 1500x 3,5ghz cpu,i was using it with XFR enabled at first but i was getting some what high temps for my liking..
besides with XFR on it would only increase it by 200mhz its too small of a jump for me so i disabled it....
my voltage for my cpu with xfr disabled was 1.2v to 1.3vcore max so i just left it alone for about a year.
i was reading couple threads earlier that if i disabled xfr i can run my cpu at much much lower voltage then what im using right now
right now my ryzen 5 1500x 3,5ghz is just at stock speed with xfr disabled and my voltage like i said was 1.2-1.3volt max so what i did was i went too
the negative offset to lower it some what i got it down too 1.22-1.25volt max and its still stable now im wondering should i try and go even lower?
or just leave it alone now?
i think i can get it lower tho should i? and what should it be?
also nothing is overclocked!
its just running at stock speed with xfr disabled thats all...
anyway right now im hitting 1.25volt max is this right for 3.5ghz?
or try and go lower?
thanks this is new to me btw ;p
the reason i dont overclock is because my mobo is asus prime 320 it has no OC capability..
