I have a windtunnel case with 2 92mm fans on the side.
My heatsink is a ax-7 with a 80mm currently on top.
The 92mm side fan is not directly over the cpu but it mostly is( it hits the cpu and the ram, while the other hits directly over the video card.)
Between the the 80mm on the ax-7 heatsink and the interior of the 92mm on the side I currently have approx 2 1/2 to 3 inches of air space.
I was thinking of purchasing the 80 to 120 mm adapter but this would leave only approx 2 inches between the case fan and the cpu fan.
It would change it from 53 to 86 cfm though at 34 db sound.
Is that to close to have such powerful fans together?
I am sure that it would suck everybit of the air coming in and then some from the 92 mm partially over it.
What do you think?
What do you think?
