- Nov 20, 2001
- Fort Wayne, Indiana
I'm about to kick it's little bootay
Ok... Got the bios configured for what seems to be OPTIMAL performance... no problems at stock speed. Ok... next I check to see how far my memory will go. Only sdram... pc133 rated at 133 cas3 and 100 cas2. Amazingly will do 148 cas2 NO PROBLEMS... tested with DocMemory. I can't POST at 149+ so I'm not sure of anything higher... because I don't know whats preventing POST.
Not a problem... chip should do 148 no problem right? WRONG!!! I can get to the winXP "Welcome" splash screen and it freezes. I say "OK I'll try less aggressive settings"... I did JUST that. Put EVERY setting to its more STABLE counterpart. Even the memory. Still does it. Will not load windows... back down the FSB to 145... still no-go. Back down to 144... ok... now we get into winXP but if I put the processor under load it freezes. Back down to 143... running Seti and Toast as I type this. Vcore is maxed out on the mobo at 1.85 and I've set the bios settings ALL back with performance in mind. Full load while running this stuff is 46*C.
Whats your take on this? (Sys specs in sig)
