- Oct 11, 2002
- The Empire State
As many of you know I made a little upgrade from a 290 to a 390 not too long ago. Anyways I played my games as normal at stock (yes STOCK!) speeds and I seem to have a "slight" temp problem and the occasional reboot/bsod. I recheck all my settings in bios, nothing out of the ordinary, and reboot desktop. Start my gaming session (FarCry 4) and after about an hour I get the reboot again, but this time I noticed the air coming from the top of my rad quite hotter than usual
I take the side panel off and restart my gaming session. I pause the game and put my hand on the backplate of my 390 and holy jeebus that sucker is HOT!! Checked temps and they were close to 80C!
Check to see if my fans are spinning, and ye sure are, but not really at high speed like they're supposed to
So as a temp solution and decide to create a fan curve in MSI to be higher and resumed my gaming session. Well this helped quite a bit as when I touched the backplate it was warm, but not hot like it was before and my reboots stopped. Figured I would have to check the factory TIM application on the card to see if that was an issue.
Sure enough when I took the heatsink off today, there was this ungodly large glop of that factory crap TIM
I mean who the hell puts on that much? Not to mention it was that dried out shat. I spent the better part of of an hour cleaning and scrubbing that cursed substance off the core and surrounding areas.
Applied a 1/2 a pea sized dollop of HT-N1 and reassembled the card. Happy to report card's loaded temps while gaming now are not reaching 50C and the backplate is just tepid warm
Pics of the unholy glob:
