One dumb question. I ordered the poly-block from overclock-watercool.com, and it comes with nylon bolts and that kinda stuff. Is that good enough to hold the block into place? Or should I get that hold down clamp thing from dangerden.com? I need a quick answer on this if possible...
Are the nylon bolts used to attach the waterblock to the mobo via the attachment holes? If so, danger den is shipping nylon bolts with their new waterblock. For use in the same manner.
I'll have mine all set up this weekend. To heck with studying!
