Home network project
FX4
My home network has kind of grown out of control and I thought it was time to clean things up. I'm going to do this as a project style post over the weekend.
Here is the mess:
The network is already built, I'm just cleaning up the cables that have grown by leaps and bounds.
I'd like to see your network map but the uploaded image is too small to read any details. :)
** NM ** I see it now...
What's up with the media converter using coax? Are the distances really that great you can't just use Cat5/6?
Running Ethernet to the family room was the issue. My basement is finished and pulling cable would have required punching a bunch of holes in sheetrock to get the Ethernet cable into the family room. These MoCA adapters work extremely well. I have no problem running multiple 1080P streams at the same time.
Cool. Only other thing I was wondering was the purpose of having a subnet for the phone. Assuming it's voip, is one home and one business?
The voice Vlan is put in a low latency queue and diffserv values are applied to the traffic. EF for voice and AF41 for signalling.
I found your problem!
You have an Apple running in there!
I kid you not, my previous Pfsense rig would NOT let anything Apple out to the interwebs. It would provide a DHCP address, including DNS, but you couldnt get even ping by IP past the router. PSP, PS3, Denon Avr1912, Roku and Boxee, assorted Android systems, MS 2k, XP, XP64, XP-MCE, 2k3, 7x32,7x64 all were able to get out with no issue but if it had an apple logo it would not work.
Yes I do, after a pile of wireless routers dieing I decided to give Apple a try. It has been the best wireless router i have bought to date. It covers the entire house and never burps, never needs rebooted. It is running in bridge mode. I think the last time it was power cycled was something like two years ago when I was working on my wife's computer in her office.
BTW: I have quite a few Apple products. Lets see:
1. Apple Extreme wireless router
2. 2 iPads
3. 5-6 iPods
4. 2 MacBook Pros
5. 2 iMacs (Both belong to my wife)
6. 2 iTouch iPods
7. Apple TV. (Don't really use it)
8. Airport Express for Air Tunes
Progress so far:
Shelves are mounted and the cable cleanup has begun.
I ran into a small problem:
While I was test fitting everything I found that the power adapter for the MoCA media converter will not fit in the power outlets with the distribution box cover closed. I had planned on installing a second power outlet to cover all three powered devices going into the distribution box. I'll have to install a small power strip now. I'm not terribly happy about this but it's the only practical solution I can see to solving the problem.
I found a solution to the media adapter transformer problem:
FX4, looks good so far! Wish I had the time to sit down and do my house properly like this.
I have a Macbook pro and an iPad on my network and neither have issues. I'm also running pfSense.
