Not true as written.Runner30 said:I'm using Cable modem ( no dialer), I have a dynamic IP .
The tech support told me I don't have to posess 2 IPs, furthermore - they told me I can connect 1 cmputer to the Cat5 connection and the other to USB connection and use both.
Is that true?
gusgizmo said:2. no, and i think they are really useless. just causes alot of problems. if you are really hardcore about security, i can teach you to harden your system, but i think as long as you keep your computer patched up, youll be fine. and run an antivirus.
Runner30 said:Thanks for the replies!
Router -- wow this is getting out of my leage.
Maybe EDIMAX router with built in firewall will do?
I think I could get some sort of cheapo duron with Linux server and IP-table but it's ridiculous for a "network" of 1 comp and 1 mom.
My modem does use DHCP.
I guess I'll do the Laptop ->Cat V -> NIC -> USB -> modem thing.
I started the whole thing because a friend of mine told me that if I add a hub/switch between my modem and internet, I can loose the firewall.I guess he was wrong.
One last question: Can I overclock a NIC? kidding.
Yes, using the USB and Cat5 connection will work just fine. I'd have the laptop use the USB personally, and then follow whatever instructions came with the modem. My SB-5100 was fairly easy to set up for dual operation, just needed to install the drivers on the CD onto the computer that used the USB port.
Runner30 said:I'm thinking about buying EDIMAX generic router.
My modem is a Motorola SB4200 cable modem with USB+Cat 5 plugs.
Runner30 said:Yes I mixed them.
PC1 has IP 192.168.0.1, PC2 -- 192.168.0.2, the Switch has IP of the provider and the modem 192.168.100.1
So all hackers can do is bomb the switch, wich is really not big deal.
I don't have a switch or router yet.It's all in my imagination now.
