- Mar 11, 2001
- Auburn California
I saw a article at hardocp that said you can cut and stack ide cables so that you have sort of a rounded cable so you can get better cooling with improved airflow, except they said the 80 wire hard drive cable may cause CrossTalk with the wires stacked my question's are will it really cause CrossTalk? and if it did can i maybe put a piece of black tape or other tape in between the stacked wires to fix the crosstalking problem? are there any opinions on this? is there another reason why I should not do this?
