- Sep 26, 2002
- Indianapolis, IN
hey, i am not so much of an expert on usb ports and i was hoping someone around here could help me. on my new case, it has 2 front usb ports. the only problem (for me) is that i am not sure how to hook them up. all of the other cases i have had were ones that had easy hookups where you just have to plug this one big block in to connect them. this new case i have has seperate connectors. i know what the usb pins look like, i just can't figure out where to plug which ones in. i check on intel's website (i have an intel board) and it didn't help at all. here's what the pin layout on the motherboard looks like this (with O's being the pins):
1
O O O O O
O O O O
2
there are 4 connectors total (i know there are 2 for each port cause they're labeled 1 and 2
so i am just going to draw one set) the lines represent a connector for each pin. the first has 3 in a line, the second has just 1 connector
3 connector:
______
ground
______
D+
______
D -
______
one connector:
______
+5V
______
if someone could please tell me how i should connect these to which pins, i would be extremely grateful!
1
O O O O O
O O O O
2
3 connector:
______
ground
______
D+
______
D -
______
one connector:
______
+5V
______
