- Apr 10, 2001
Hoot,
I followed your recent article (although now I can't find it on oc.com?) about putting in a digital themometer from crazypc.com. Mine came today (smaller than I thought) and I cut the rubber coating back to expose the wires, then trimmed the coating around the thermistor. I attached it to my Duron 650 @ 952 1.85V with a drop of superglue making sure the thermistor touched the edge of the die. I put my water block back on and fired it up. I watched as the temp quickly rose to 26 C. Room temp according to my cheap radio shack digital is 26.3? Then it goes into windows. At the logon screen I wait to see if the temp continues to rise.....28.4 C. I log in and when MBM5 shows up it reads 40 C (via insocket thermistor reading).
As I type this MBM shows 33 C and the crazy PC digital theometer shows 22.9 C. My RadioShack digital indoor outdoor shows a room temp of 26.3 and an ambient (measured 1" from processor) as 32.0 C. Are these crazyPC.com digital themometer temps reasonable. I guess I'm so used to MBM I'm shocked at how low the temp actually is. I ran prime95 torture for about 30 minutes and never saw temps go over 29 C (making my calculated C/W = .11 using radiate 2? Yet when I stopped the test the temp quickly dropped back to around 20 C. So I know the thermistor is touching the CPU as the temps rise and fall very quickly. I'm just suprised the insocket thermistor is this far off, and seems to get farther off as the temp rises.
What are your thoughts?
