- Aug 25, 2001
- Ontario, Canada
I know I've seen a few threads like this before (with no solid solutions to them)but... my LAN speeds are horrible.
2 x Win2k Pro SP3 boxes (P3 800 and P3 1gig)
Connected by an AOpen 10/100Mbits 5-port hub.
Also connected to the hub is my 10Mbits Cable modem.
Both machines are set to 100Mbits/half duplex.
From ComputerA, sending to computer B:
50 megs transferred in 20 minutes (aprox). -- estimated 37 minutes at the beginning
From ComputerB, sending to computer A: (same data)
50 megs transferred in 2 minutes (aprox). --estimated 10 minutes at the beginning.
One computer is running a D-Link 530tx, and the other one is running a Phoebe 10/100 NIC (Realtek) --could the realtek be the problem?.. i don't have another nic around..
I understand that on a 10/100 hubbed network, introducing a device like a 10Mbit cable modem will effectively slow all traffic down to 10Mbits, however, when I remove the cable modem, nothing speeds up. (that, and 10Mbits should yeild me 1.25Mbytes/second ideal throughput.
Hard disks are almost idle while transferring (no thrashing).. they're fully defragmented. There is network traffic and the occasional collision @ 100Mbits. Only protocol installed is TCP/IP. They're physically right beside eachother.. i havn't checked the cables though, don't got any extras around..
Oh yeah, they are both registry tweaked for cable internet:
tweak output
www.broadbandreports.com/1036902502]internet bandwidth[/url]
my RWIN is a bit high, could that be a problem?
also, they're both using ZoneAlarm, but I had this problem before I installed zonealarm.
anyone have any ideas?
tweak output
