horrible water cooling temps
NoKtEm
Hey everybody, I finnally got my water cooled rig up and running... I was almost sure that i'd be running at 35 degrees celsius max because it's a duron 800 but for some reason it stays constant at around 46 degrees... the case temp is said to be 26 and i tried tightening it more and more =( the springs on my maze 3 are about an inch to half an inch long now.. anyone have any clues? im almost thinking about going back to air because i'm not even doing anything cpu intensive yet :(
NoKtEm
NoKtEm
thanks for the input, i'll try readding AS and remounting the waterblock... would it also help if I bled it completely? it seems like there's still quite a bit of air inside the radiator
btw here's my specs
Duron 800
Ehiem 1250
Maze 3
a D-tek Pro core radiator (chevette)
shroud with one of those enermax adjustable fans (it's on max)
1/2 inch tubing
Thanks for the input!
X2sandman
Melrose, MA
Yes in order to get good temperatures, it helps to bleed the whole system. Air in the radiator can hurt temps quite a bit.
NoKtEm
NoKtEm
I have a Iwill kk266, although soon i'm going to get one of those NF7-S 2.0's with a brand new 2500+ barton =D
NoKtEm
NoKtEm
i've noticed my cpu temp going down when i blew a fan there haha I thought it just cooled down the copper
NoKtEm
NoKtEm
I remounted the water block and reapplied arctic silver 3.. =/ still getting the same temps, shoudl I just give up and blame it on the motherboard? heh
