Ghost can load images onto a RAID without any problems. I run an image server at work that uses a Ghost application for preloading machnes. As to Ghosting from a RAID array to another storage device, it becomes much more difficult to establish the parameters, as I haven't tried it yet. In our normal usage, the images are loaded by using a floopy boot to network share, and Ghost can be quite particular about the disk structure on the machine being loaded. At a minimum, I would expect that you would been a custom boot disk with the RAID drivers and current configuration, if using it within a single machine. Most likely, you'd also need the Corporate version as it will have a more complete selection of operations. Unfortunately, I can't be more clear due to lack of experimentation, since we use DLT tape autoloaders and libraries for our current backup solution.
