Hot Mouse
travioli
Norwalk, CT
This mouse is litereally hot. I have had a Logitech MX 700 rechargable mouse for a while now and the past few times I have charged it, when I remove it from the charger (whether its compeletly charged or not) the mouse is hot to the touch. I am pretty sure its the batteries that are heating up, but I was wondering if anyone else had this problem, or if I need new rechargable battieries, or if its normal. Thanks!
Bensa
Its normal, when current moves through any material with even the slightest resistance, it will warm up.
StreetPharmacy
Or maybe a secret government shipment of plutonium accidentally got directed to the Duracell factory, and your batteries are giving off Gamma radiation....
nah...
Dc5e
MA
i've never noticed it with mine.... maybe you have a faulty one? who knows, but in general thats normal with electronics anyways
travioli
travioli
Norwalk, CT
Yea, I just don't want to go to use it one day and its oozing battery acid all over the place or something. Do you think a pair of regualr rechargable batteries would work in the mouse, provided its the same voltage? The ones in there now are only 1.2 V each, and I know most batteries are 1.5V.
Dc5e
MA
aren't all rechargable batts like 1.2 and regular batteries 1.5v? anyways what part of the mouse gets hot? the batteries?
Dubbin1
Ohio
Alkaline batteries are 1.5 but when you get into NiMH then they are 1.2 volts each which is probably what is in your mouse. That or nicads.
travioli
travioli
Norwalk, CT
I am pretty sure its the batteries that get hot, but I can feel the heat on my hand when I use the mouse, I will charge it again tonight and check for the heat more closley, and if it is the batteries, I might just get some new rechragable ones to put in and see what happens. Thanks for all the help everyone!
