I began with water cooling about 10 or 12 years ago. I went back to air cooling for awhile, but the truth is that water cooling gets into your blood. So when I built my latest computer, I decided to head back to the water.
I used a combination of older and newer components to build an external water cooling system. My mid-tower computer sits on top of this box. The tubes run in and out the rear of the computer case through one of the expansion slot panels. All of the other components for water cooling are in the external box.
I've tried pushing my Core I5 2500K CPU a little harder. I can get it up to 4.5 without changing any voltage, but it just doesn't seem to be stable. I was seeing idle temps running about 40 - 42 degrees C, which seemed too high for stock voltage on a water cooling rig. Running Prime was pushing the temps higher than I liked and I kept getting the occasional Blue Screen Of Death. And the water temps inside the reservoir in the box kept gradually climbing. I was routinely seeing temps of 48 degrees - which is just too hot to effectively cool a CPU. So I figured something in my water cooling setup still needed work. BTW, I have a digital meat thermometer with the probe inserted into the water reservoir.
My water block is a D-TEK Fusion II. I guess it isn't the absolute best block around, but it certainly should be able to adequately cool a single I5 CPU. The silicone tubing is 3/8 inch ID. I have a good sized Eheim aquarium pump that is more than equal to the task. I have some type of Arctic Silver paste. I favor a little more, rather than too little of the paste.
I reasoned that the two fans were doing a reasonably good job of cooling the radiator. The air exiting the radiator was quite warm to my hand. My radiator is an older converted auto heater core that was sold under the name "The Big Momma". It's 6x6 square and about 2.5 inches thick. It was always one of the top contenders from a few years ago. I have two 120mm fans within a shroud to push-pull air through that sucker. Each fan is about an inch and a half from the radiator surface. And they seem to move the air through it effectively.
My theory was that too much of that warm air coming from the radiator is being trapped within the wooden box. I did a temporary experiment using a 3 inch fan at the rear of the box to remove more of this inside air. The temps on my CPU went down by at least 4 degrees C at idle. And the temporary cardboard panel I used for this experimental fan was nowhere near tightly attached to the box. Even with only a rated 30 CFM air flow, the inside of the box was defintely cooler. So it looked like getting more of that hot air out of the box might improve the cooling of my CPU.
So I bought a third 120mm 120 volt fan. It is supposedly rated at 65 CFM. I'm now constructing a labyrinth air mechanism I favor to reduce sound while I try to get that excess heat out of the box.
These are just cheaply made Radio Shack 120 volt sleeve bearing fans. I say cheaply made instead of cheap. The Shack gets $26 per fan. I already have the two radiator fans on a controller. I use one of those rotary fan controllers like you use for a ceiling fan. I've decided to put this last exhaust fan on a separate controller. I already had one in my junk box from a previous project. This should allow me more options to regulate things. My logic is that having more controls is usually a good thing.
If anybody can think of other things for me to consider, I'm open to ideas.
Bach On!
Bach On!
