- Thread Starter
- #41
Modz,
Would you mind telling me a little more about your Swiftech MCR320-QP? That rad looks like it might be about what I need. I'm thinking I need either a 120x3 or a 140x3. Since all I'm looking at cooling (at this time) is a single I5 2500K, it looks like the 400 watt cooling capability of the MCR320-QP would more than cover that. And it is almost half the cost of a 140x3 rad, like the Aqua Computer AirPlex Revolution.
I already have two new Zalman ZM-F3 120mm fans. I figure I can get more. I bought them about a year ago because they were rated pretty well for a balance of quiet/output. So they should be close to some of the newer units. They included a resistor that can be used to run them in silent mode. Or you can run them at full voltage. Silent = 900 RPM. Full Power = 1800 RPM. Silent = 20 db. Full power = 34 db. I don't see anything on the box that gives a CFM rating. And they have sleeve bearings instead of ball bearings. That often means quiet, but probably not as long a life.
My idea was to start off with just three fans and see how my temps look. Then if it is needed, I figured I could add three more fans for a full push-pull setup.
There seems to be a debate about push vs pull. Some favor one over the other. I figured to do some experimenting to see which gives me the best results. How do you configure yours?
Finally, the choice for getting power to the fans seems to be either a high dollar fan controller, or several of those Molex to 3 pin converters. How do you do it with your system?
BO
BO
