- Jan 24, 2002
- my computer chair
Because i don´t have money to buy a new GFX card i decided to OC my V3 2000. So i vent to the local PC shop and bought a nice looking Blue Orb. I used the thermal compound that came with the Orb and some Super Attack glue to hold the orb on the GPU.
(too bad that the holes on the Orb don´t fit the one on the gfx card).
So how much can i OC the cardwith the current setup and which prog to use????
Will i be able to OC more if i make memory HS and if i add a fan to the backside of the card??????
THANX
THANX
