Technologies of RRC Kurchatov Institute
Artificial Diamond Coating and Thin Film Technologies
The new method of producting films of artificial amorphous diamond has been developed at the RRC:
at low pressure;
at low temperature;
by means of ion spraying of pure graphite.
This is a universal technique that allows to produce films of any metals, oxides, nitrides, etc. within one and the same process.
This method allows to produce artificial diamonds in coating form virtually on any solid bases, to produce multilayer coatings with semiconductor properties, as well as unattached films of an artificial diamond.
The artificial diamond produced with this new method possesses enhanced mechanical properties. Thus, it surpasses natural diamond in strength by a factor of 3-4, and in hardness - by a factor of 2-3.
When applied to a product, the diamond films allow to increase its service life at least tenfold.
Advantages:
the coating is applied without heating of a product;
high class of a product surface finish is retained after the coating has been applied;
formation of ultra-thin (3-10 continuous films;
absence of essential limitations as to a product overall dimensions (up to several square meters);
the original technology is protected under the author's certificates in Russian Federation, it is patented in the U.S., United Kingdom, Germany, Japan, Switzerland and France.
The technology allows to produce coatings of an artificial diamond with an amorphous structure (amorphous diamond):
0.3 nm to 3 mm thick;
to apply coatings on both sides of flat products at a time;
to apply coatings on complex geometry products;
to apply coatings on products of metal, glass, ceramic and some kinds of plastic.
Level of readiness: the experimental system for application of the coatings is built at the RRC.
Proposals:
delivery of installations for application of the coatings;
development of special-purpose systems;
vending of a license for the method.
Characteristics
Mohs' scratch hardness 10
Microhardness, kg/mm (2-3) * 104
Tensile strength, kg/mm2 700-800
Modulus of elasticity, kg/mm2 150000
Density, g/mm2 3.4-3.6
Adhesion to carbon steel, kg/mm2 600
Refractive index 2.6
Electric strength, V/cm 2 * 106
Specific electric resistance of 5 * 106
non-alloyed material at T = 200 C, ohm * cm
Thermal coefficient of resistance Negative
Chemical resistance Is not reactive in boiling HNO3, aqua regia, does not oxidize in chromic mixtures at T=3000C.
Heat resistance of the diamond film,0C 400
tel: (095) 196 9997
fax: (095) 196 7262
E-mail:
[email protected]
