The 8kha+ has a bit of extra Magic somewhere
, and that is all there is to it.
Nothing else can sufficiently explain to me why an older, slower chipset (KT266a) is still VERY competitive when compared to newer ones like the KT333 and KT400s; in fact an overclocked pc based on 8KHA+ will be faster than a KT333 chipset board at the same clockspeed due to the lack of a 1/5 divider- and they seem to hit the same (or BETTER!) fsb speeds.
I have run at 2Ghz with my XP1600 (unlocked) using an 11x multi and 184mhz of fsb- since I only have a 1/4 divider that gives me a pci speed of 46mhz. (normal operation is slightly less- I'm still ramping up
The 8KHA+ has great OC features as well, and is easy to do a vcore volt mod and a vmem volt mod....I have also found them to be very reliable in addition to screaming fast!
As far as HOW to achieve those speeds.....slowly, lest you corrupt your os installation
Quick list of my rig:
Enermax 431w psu (adj 5v line mod)
vcore mod-2.1v max
vmem mod- 3.5v max
mosfet mod- more stable 5v line
XP1600 agoia y 0213
pc2100 ddr (generic, micron chips) 1 stick
A couple of tricks I have found: don't use the middle ram slot- it seems to drop the max FSB by 5 or 6 mhz. 1 Stick usually does better anyway, so if you can afford the loss in ram, use just one.
I always remove the northbridge heatsink and lap it, then use plastic nuts and bolts to re-attach with thermal compound(
[email protected] is better there for me.) I think that may help the FSB a bit
This IS a 5v hungry board- if your readings are low, but good at a molex, find the thread that describes the mosfet mod, and a few other tricks that may help.
Thats all the tricks I can think of off the top of my head
