Athlon XP Model Numbering System
Starting with the Athlon XP processor launch, AMD will be introducing their new model numbering system as a bridge to their plans for a unified number system in 2002.
The new AMD Athlon processors will be sold on the basis of a relative performance scale. These models numbers will pertain and convey a performance level relative to other AMD processors. As of now, the Athlon XP processor model numbering will be based on the Thunderbird core Athlons. Below you will see the chart of AMD Model numbers and their actual operating frequencies.
The new Athlon XP 1800+ processor will actually be running at a speed of 1.53 GHz, not 1.8 GHz as the name might suggest. Similarly, the 1700+ runs at 1.47 GHz, the 1600+ runs at 1.4 GHz and the 1500+ operates at 1.33 GHz. AMD’s new scale compares their new processor to their Thunderbird. This means that the Athlon XP 1800+, which runs at a clock speed of 1.53 GHz, performs nearly the same as an original Thunderbird core Athlon processor would at 1.8 GHz. Along the same lines the Athlon XP 1700+ running at 1.47 GHz performs like a Thunderbird would at 1.7 GHz, and so on and so on
Hi, I don't know if this will help but its right from www.amdmb.com i just cut a small section out but they have a really good article all about the xp and what the numbers mean and what the numbers are based on.
