- Mar 7, 2005
...also, what are the signs of PS failure, aside from fluctuating voltage (which my ps does not have)?
this topic could alternatively be titled 'Help! i think my PS is dying, but i'm not so sure...'
-=WARNING=- long, semi-related paragraphs ahead...
i think my PS is outputting an insufficient amount of power. ever since i installed a sunbeam rheostat, other installed components have been failing left and right; i lost THREE hdd this year, all attached (one at a time) on the same power line as that rheostat.
5 minutes ago, i thought my dvd burner (the only component now connected on that power cable) also died; it wasn't responding when i pressed on the eject button, it wasn't lighting up and explorer wasn't detecting it. i pulled open the case, rechecked the connections and when i tried to reboot, the burner lit up and ejected as per my commands -but now suddenly the pc was acting as if all the hdd were missing. i immediately shut off the system and detached the burner and viola, now i'm booted in and typing on the pc. all this leads me to believe there is *somehow, suddenly* insufficient power for my burner and all my hdds -and this accursed rheostat.
previously, this pc had been running with 3 hdd and 1 burner for nearly 3 years straight.
--the reason i suspect my psu is failing is because i've actually encountered all this before:
shortly before my old psu (from an even older, 1995 era pc) erupted in sweet white smoke, the same afflictions haunting my current setup haunted my old rig: hdd were dying left and right, the pc acted slow and unstable despite being 48h prime95 stable and virus free, and one of the last components to fail was my old, trusty cd burner; one day, after inserting a cd i had burned, suddenly it didn't seem to be reading the disc and it wasn't ejecting as per my commands.
it wasn't long before the pc died. some of the hardier components continue to function beautifully in a new pc (ram, cdrom, floppy drive). others, not so much (ALL my hdds, *********!! ********* TO HELL!!).
before that psu died, i also added a new component to that system: some new ram and a storage hdd. calculations showed my psu OUGHT to have been able to power this rig, but it was shortly after this that problems began to appear, and **** started to die.
-of course, it was summer and this article:
http://www.motherboards.org/articles/guides/1487_8.html
has been enlightning in suggesting that perhaps the elevated temperature was causing my psu to provide far less power than it was rated for.
my current (aging) setup:
mobo: nf7s v2 w microcool northpole nb1 (40mm fan)
cpu: xpm2500 @ 200 MHz x12, 1.725v
cooler: 90mm panaflo
ram: 2x 512mb pc3000 kingston hyper x @ pc3200, 2.6v
gpu: 64mb radeon 9500 @ stock
hdds: 1x200gb seagate barracuda + 1x80gb western digital (on seperate power cables)
optical: 1x lite on ld3540a dvd burner
network card: 1x readynet 10/100 ethernet adapter
floppy drive: 1x floppy drive
case fans: 2x 80mm panaflo
rheostat: sunbeam rheostat powering the casefans and northpole (draws power from same cable as dvd burner; is this bad?)
psu: 300 watt antec sl300s
multimeter readings:
12v: 11.93-11.92v
5v: 5.10-5.11v
3.3v: 3.19-3.18v
so, what are your thoughts ocforums?
EDIT: oh wow, there's a swear filter now. neato.
12v: 11.93-11.92v
5v: 5.10-5.11v
3.3v: 3.19-3.18v
