How can i determine if.....
SoLDneR
My barton 2500+ is locked or not,its because i saw my serial :AQZFA 0342 TPMW,some say its unlocked and some locked.Its not install yet.Is there a way to determine PHYSICLY if its lock or not ???
Thanks
its a week 42
and that stepping both comes in locked and unlocked flavour.
With only 1 way to tell what one. Test it.
Sorry but thats the only way to find out
well... now people have found a way to unlock them. So if you end up buying it and it is locked, you still have hope.
http://www.ocforums.com/showthread.php?s=&threadid=244237 end of thread
Doesn't appear to work with nForce2 mobos yet.
c627627 said:
Basically, the method involves heavy modding of the locked chips.
AMD Mobile CPUs have this 'PowerNow' feature which allows voltage and multiplier changes in order to preserve battery life.
Besides modding the desktop CPU into a mobile CPU, you need to have motherboard/chipset/BIOS support for PowerNow which not all boards do.
You also need to boot into Windows with your locked multiplier and the FSB with which you can boot into Windows but you cannot change the FSB inside Windows.
So with this method, remembering that MHz Speed = [FSB] x multiplier,
FSB can be changed only before you boot into Windows but
multiplier can only be changed after you boot into Windows.
...with limited success so far.
Yeah but the people who can change the multis inside Windows can't change FSB inside Windows, it appears.
You can't change the multis inside Windows with your NForce2 like they can on the other hand too.
