How do i change the vcore
TripleH
my mobo doesnt support voltage changes through bios so i need to cut/connect some bridges, could anyone point me in the direction for a table or chart that shows me which bridges to alter, also, i dont think that the morgan duron and the spitfire duron bridges are setup the same, are they the same as the XP then?
Ozzman
hmm if u can do a vmod then u might be able to up it using that.. whats ur motherboard? can anyone comfirm what i just said?
David
Forums Super Moderator
Close all L7 bridges = 1.85Volts
T
TripleH
I dont want a full 1.85v i want something along the lines of 1.78 or 1.8v just to keep my 1.2ghz stable, freezes after a bit, and i know it isnt the temp, temp is about 46-49 under load, not good, but im sure its not enough make it freeze, im not going to change voltage till i get new hsf anyway though so i can still do some lookin up on it
