- Jul 6, 2002
- Coventry Rhode Island
Ok I had made repair install and now its seas my home Dir is E:\ not C:\ and some programs donot like this when I went to www.pcpitstop.com I found that theres still a C:\ there can any one help
lclark2074 said:how do you make screan shots i will show you what it looks like
its seas you cant make changes to root leter or vollume infoDavid said:If its XP go to Control Panel - Admin Tools - Computer Management - Storage Management. It lets you change drive letters there
I'm sure that also at one point I had a neat little proggie that went through the registry and could change every reference to drive X: to drive Y: or whatever drivers were concerned.
redduc900 said:Windows can't modify the drive letter of your system volume or boot volume.
chrisman said:Do this:
http://support.microsoft.com/default.aspx?scid=kb;en-us;223188
I've had to do it on a few computers, including mine. Works great.
I'm sure.Panzerknacker said:Are u sure it worked great all the time? MS warns for that u should only use this way when ur device letters suddenly changed, not when you just installed windows and the system drive apeared as E: from the beginning. I think I'm going to try it when I made a image of my raid array, cuz since I made the raid array (which holds my system files) is F:, my backup drive is C: and my CD-rom drives are D: and E:, totally messed up and very anoying.
