how do i get SSE back?
emericanchaos
emericanchaos
Williamsport, PA
when the new gromacs came out they switched AXP's to 3dnow emulation cause SSE was causing instability. the new beta is supposed to fix it but i don't know if i just replace the .exe or if i have to download a new gromacs core.
Kendan
Senior Punk
Dark side of hell
emericanchaos said:
i downloaded the 3.25 beta. do i just replace the old winFAH.exe with the new beta and that's it? or do i need to delete FAH_core78.exe?
I had to:D
Correct procedure for using SSE on an AMD rig as of right this minute.
1. Get the beta client from here: http://folding.stanford.edu/beta/beta.html
2.stop the client
4. Rename the new beta client 3.25 to replace the one there now.
5. Delete FAH_core78.exe
6. Make sure you are using the -advmethods and the -forceasm flags (the Forceasm flag is the one turning on SSE now)
7. Restart the client:D
