how do i use over 12.5 multi???
renots
my setup is a7n8x dlx rev.2 running xp1700+ @ 2079 (12.5 x 166fsb)...i want to up multiplier coz memory only 333mhz...until i get me PC3500 sticks!!!
well, for the higher multi's, i believe u need to short some bridges with a 9V battery or something :-/ I have the same chip, and I just busted my FSB to 200MHz (400 double pumped) and ticked the multi down to 11.5 - - - What RAM are u using? if it is true DDR333 then it would be able to do 'close' if not true DDR400 speeds - - - you do know that specs are meant to be broken, right? lol - - often memory can run anywhere from 33 to 70MHz faster than it is rated. So if ur using DDR333 try upping the bus ^_^ (you may needa up the vDIMM voltage a little though, and depending how far you go, relax your memory timings)
(BTW: Those Rev.2.0 boards are supposed to own, the 1004 bios even supports up to 600MHz FSB (300x2)! Beats the heck out of me if any ram on the planet can do that though...or if the board actually can handle all that sheer awesomeness...lol)
thanx for the help...up the fsb to 200 now running 11 x 200 @ 1.65 (1700+ @ 2191)...this is standard cooling...cant wait to get me better mem and hsf!!! oh chip is dlt3c jiuhb
renots said:
thanx for the help...up the fsb to 200 now running 11 x 200 @ 1.65 (1700+ @ 2191)...this is standard cooling...cant wait to get me better mem and hsf!!! oh chip is dlt3c jivhb
I think you mean JIUHB ;)
Oh, and:
WELCOME TO THE FORUMS!
week into my first time overclocking
damn...now i have my 1700+ @ 2205 w/ 1.65vcore (200fsb, multi11)...i changed my hsf now using TB retail box heatsink/ys tech 70mm fan...gave me temps idle/load at 44/49...so, running prime95 for 3hrs...stable??? im new to prime95...think i need some input this way i know system is actually being burnin and stessed for stability...more on my overclock when i get my slk800...wonder what i can achieve with this...thinking i may be able to clock at 2400 coz i've booted up to desktop before it froze...also running 1.75vcore with temps idle/load at 51/???...didnt have a chance to view load temp...well, 2205 stable at 1.65vcore with my current hsf...hopefully...thanx to all who post on overclockers forum!!!
I'd say 2.5ghz looks quite doable with your setup with an SLK800. Don't be too afraid to give it some more juice, with that kind of cooling. Good luck, and enjoy.
Do you have to short some bridges for a 1800+ also? I thought that the nforce2 allows you to change multipliers. I know I could with my 2100+
dunno bout shorting bridges on 1800+....i didnt have to short any bridges on my 1700+...using a7n8x dlx v.2....me just a noob clocker here...have to start somewhere...heheheh!!!
Why does it show up in the bios if it just goes back to normal. Is there another way to do it other than shorting bridges because im not to comfortable with doing that
