How do I wire fan for RPM readout
arden
Pa.
I want to make a 4 pin connector so I dont have to use mb power.I know you can buy one , but I could also wire one with spare parts I have .A wire diagram would be nice. Any one done this .I'm sure several have.
The Doors
Vesuvius Senior Ocer
Athens - Greece
Hi arden,
you can take a look here, but the Rpm signal work only if the fan is @12v, or more deeply, want a ground of -12v, absolutly not in the other way ;)
Tweak
The Doors said:
Hi arden,
Doors is right you will need to have it connected to -12v power and have the RPM wire connected to the motherboard. Personaly I don't see why you would want to not use motherboard power
The Doors
Athens - Greece
Personally I've tried only with 7v, and doesn't work at all the Rpm signal, but I suppose which is the same with other voltages or a rheostat ;)
A
arden
Pa.
The reason is I dont want to burn out the fan header on my abit kt7a mb. I'm using a sk6 with delta fan and have heard it could burn out the header.
The Doors
Athens - Greece
And infact this is the way to go, coz Delta's fans, like clone, are really stronger, and wants 'higher' wattage to work, wattage which the Mobo can't provide! ;)
