How do I.....?
Cisco Kid
Senior Member
Yep I know it is a silly question but how do I post screen shots of Sandra 2001 showing some results with my new KT333 based board?
Also how do I post a screenshot of 3D mark2K1 after running it?
Not sure if this is the right place to post the question.
Cisco Kid
funnyperson1
Senior Member
there should be a button on your keyboard marked printscreen push this and it will copy the entire screen to your clipboard.....then paste into paint and edit what you want, save file to hdd, then when you post attach the file....
funnyperson1
Senior Member
Kato said:
this is even more silly.....
where can i found the clipboard? >_<
the clipboard is the "location" where windows stores anything that you attempt to copy...when you higlight something and say ctrl-c then its been copied to the clipboard and when you say ctrl-v you paste it from the clipboard...
Kato
Addicted Tweaker
Toronto, Canada
oh stupid me, no such thing as a folder of clipboard....just prt scr and ctrl-v in paint.....darn, not my night tonite!!!:D
C
Cisco Kid
Senior Member
Thaki Thanki, got it figured out , the simplest things hehehe
Cisco KId
funnyperson1
Senior Member
there are no stupid questions here:)
rogue1979
Las Cruces, NM
This is a test, hope it turns out OK.
Edit: crap, it didn't work. I think the file is too large. It was 2.25MB, I went into paint and edited it but only got it down to 1.75MB. Isn't the limit 1.04MB? If so how do I make the image a smaller size file?
futura2001
Bellevue, WA
You are saving it as a bitmap. Bitmaps are per pixel images that take up a lot of space, convert it to a Jpeg and keep it under 50k. Nobody likes a bandwidth hogging image...
Futura
RainMaQer
3D God
Fort Wayne, Indiana
Just some FYI stuff... but if you press JUST Print Screen it will capture the whole screen... then you have to edit it to get the sandra or 3dmark screen... if you press alt+print screen you'll capture JUST the active window... in sandra that would be JUST the bench results screen (not the whole program) and the same goes for 3dmark... little time saver :D
