pak Member Joined Mar 21, 2005 Location Tracy, ca Dec 5, 2006 #1 I was able to disable it before, but I recently reinstalled it and I cant get it to stop starting up on boot. --pak
Seven Member Joined Mar 7, 2004 Location Los Angeles Dec 5, 2006 #2 Have you tried the settings menu yet? Otherwise you could try the Start>Run command to turn off steam.exe on startup. 7
Goateh Member Joined Apr 27, 2003 Dec 5, 2006 #3 ALso in windows XP there is the msconfig option that will allow you to see exactly what is loading on startup and stop it that way
I Indyxc1 Member Joined Oct 6, 2002 Location W. Lafayette, IN Dec 5, 2006 #4 That's the pain with steam, even if you disable start with windows, is still does (for me anyway). A solution is: GO to start>run type in "msconfig" hit enter. Click the startup tab, and steam should be listed. Uncheck it and reboot.
SolidxSnake Member Joined Dec 26, 2004 Dec 5, 2006 #5 It doesn't startup with WinXP for me... You can definitely do the MSConfig thing. I personally like to go to the registry and edit the keys myself
redrumy3 Member Joined Mar 6, 2006 Location New York Dec 5, 2006 #6 View>Settings>interface and uncheck run steam when windows starts Attachments untitled.JPG 20.5 KB · Views: 350
Mathersalan Member Joined Jun 1, 2005 Location South Carolina Dec 5, 2006 #7 It doesn't start up on me running Windows 2000 SP4.. must of accidentally selected that option
