- Feb 4, 2002
- Wethersfield, CT
How do you run more than 4 IDE Devices? Do you need to buy an IDE controller card in order to do this and how does it work? How money more can I add?
customrig said:How do you run more than 4 IDE Devices? Do you need to buy an IDE controller card in order to do this and how does it work? How money more can I add?
WillysNut said:
Other then spending money on a card, you could just use a master/slave setup on an IDE channel. You obviously need a cable that has two IDE connectors, then you need to swich the jumpers on one of the two drives from "Master" to "Slave". That will allow two devices to communicate on once channel. You do pay a performance price for this this type of setup but for a temporary solution...it works!![]()
Darrenct said:
His problem is that he has already done that with all his connectors. He probably has two IDE headers, each with two drives.
WillysNut said:
His sig says he has an AK35 "GTR" ...the R meaning RAID. The board has 4 IDE connectors so he could have more than 4 devices with a Master/Slave setup. Not sure though how IRQ's come into play and what the top limit is.
Garfield said:Do you suggest purchasing a RAID card?
donny_paycheck said:
Next is U320 SCSI RAID!
