- Apr 29, 2002
Just last weekend as I was attempting to install w2k3 above 98 & w2k on my WD 80Gb SE, things went terribly wrong. Things got so bad it wouldn't boot no matter what I did. It tested OK using the WD Data Lifeguard floppy.
So I just swapped my (both WD80GbSE) master & slave around and reinstalled both 98 & w2k. I've been in the process of picking the stuff I wanted to keep off the old drive. Just in time too.
Everything on both drives showed up as healthy partitions in w2k just last night. I didn't do any mantenance on the older HD other than move files over to the new one.
This morning I found the PC in a bootdisk failure mode. After several attemps to boot, I used my Smart Boot Manager floppy to get in to w2k. Neither the BIOS nor w2k see the older drive anymore.
If it's the HD, the non boot issue could be because the survivor was in master mode without a slave.
If the controller channel blew, wouldn't there be something about it in the BIOS boot screens? I'm going to try hooking both up separtly in stand alone mode just to see if it's really the hard drive.
Any constructive input would be appreciated.
TIA,
TIA,
